samsung rs20ccms -NOT THE USUAL!!
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries samsung rs20ccms -NOT THE USUAL!!
  • #29233
    PINKY
    hi guys, this is the newer type without the fridge evap cover etc. it has a baffle assy in fridge instead. The Diagnostics are clear but fridge at room temp and freezer at +6
    Have changed the main board which fired up and ran ok for 5 days but now gone back to fault again.
    I have got a couple of these doing same thing at the moment so would like to know if anyone else has had this as well?
    cheers fellas
    #222440
    robbo1973
    Re: samsung rs20ccms -NOT THE USUAL!!
    normally the freezer evap will be frosted up always defrost sensor at fault change that and should be fine done loads. i am sure this is the older set up and not the newer as you said with a fan at top of freezer forcing air into fridge.
