Samsung RS21
  • #56512
    MKR
    I have two of these that are causing me some grief.
    The first had various errors on diagnosis (4 errors = 03, 04, 07,and 11), affecting both the fridge and freezer sections.
    In the fridge I checked and found the fridge sensor was faulty and the fridge thermal fuse was O/C.
    I had already changed the fridge fan cover previously.
    So I changed the fridge thermal fuse, fridge Evaporator sensor and defrosted the evaporator. I checked the main heater and drain heater, both were OK.
    I then checked the freezer evaporator heaters (which were OK) and just changed the evaporator sensor for a new black one.
    Today I was called back to find the freezer fan was still not working. I changed the fan (even though it tested ok) but still nothing. I checked the light switch, and then rechecked the heaters thermal fuse and sensor… every thing is perfect, but the fan still doesn’t work, giving an instant error segment (11 F-FAN ERROR) when entering the diagnosis menu.
    So is this a pcb error or have I missed something?
    The second is similar to the first…. and is sitting in my garage. The only error code is the normal 04 R-FAN ERROR. The fan cover and evaporator are not frozen up…. I have tried new new fridge fan cover and light switch, and checked fridge defrost heaters, thermal fuse and sensors.
    But I still get the code 04 R-FAN ERROR.
    Any ideas?
    #327818
    Re: Samsung RS21
    Have you changed the pcb ?
    Bryan
    #327819
    MKR
    Re: Samsung RS21
    r600a wrote:Have you changed the pcb ?
    Bryan
    😆 No…. should I?
    #327820
    MKR
    Bryan do you still do samsung training for these models?
    #327821
    Re: Samsung RS21
    Hi MKR
    If your at coventry at the meeting i will give you the pointers needed.
    Bryan
    #327822
    MKR
    New main board fitted to garage fridge… fault gone.
