Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › samsung rs21 blues
- This topic has 12 replies, 4 voices, and was last updated 18 years, 9 months ago by
samsungblue.
June 29, 2007 at 9:42 pm #28595
samsungblue
ParticipantLike so many (it seems) I have a three year old samsung rs21(JGRS) with a common fault.
Freezer is fine, fridge warm. Already replaced the iced up fan, the thermister sensor and thermal fuse.
Still no joy and I am now at a loss, can someone help? The fault code is the bottom bar on the fridge side.
June 30, 2007 at 7:23 am #219067Dales-Electronic
ModeratorRe: samsung rs21 blues
Indicates that you have a problem and will need to replace the evaporator cover – available from Shop@ in the left navigation bar.
June 30, 2007 at 12:08 pm #219068samsungblue
ParticipantRe: samsung rs21 blues
very helpful, I need a new evap cover anyway as it’s been on and off so much now I am sure you are correct, the insulation is very tatty/squashed up. Why would an entire cover be needed, would new strips of insulation not do it? The polystyrene will be good as new surely?
Only worry is that despite new sensor, new thermal fuse and new fan I am not convinced the fan is running – the evaporator gets iced up very quickly presumably as there is no airflow. Could there be other reasons for the fan to stop?
My thermal fuse lead is plugged in to the top socket and the sensor at the bottom (defrost heater middle). The units are exactly where the originals were ie in the white clip (sensor) top left evaporator and the fuse is behind on the bottom right.June 30, 2007 at 7:24 pm #219069Dales-Electronic
Obviously from time to time fan motors burn out – cant say I’ve seen more than the odd one in the two years we’ve been authorised to service them. However, if its any comfort to you the evaporator cover comes complete with a new fan fitted and this usually clears the fault unless you have a defrost heater fault.
June 30, 2007 at 8:55 pm #219070samsungblue
Dales-Electronic wrote:Obviously from time to time fan motors burn out – cant say I’ve seen more than the odd one in the two years we’ve been authorised to service them. However, if its any comfort to you the evaporator cover comes complete with a new fan fitted and this usually clears the fault unless you have a defrost heater fault.
as I said theres a new fan fitted already, it was the first thing I changed as the original ice up suggested a burn out to me. I have now checked by hooking up all components such that I can see the fan and it is in fact running intermittently which I assume is normal.
the current situation is (with all components re-fitted as per normal)
fan – OK, seen it run
sensor – new so assumed OK
thermal fuse – new so assumed OK
cool zone set for -1 but clearly not at this temp.
cover assembly, no ice (but wet) new foam tape fitted to seal ducts, all airways seem clear. ‘servo’ style flap in top centre is open (guessing this is something to do with power cool).
Freezer steady -20 on display, fridge now +18 though set at target of +4
My main suspect therefore is now the defrost heater – would this make sense to you? From a thawed state on the fridge side the evaporator ices up in about an hour. BUT what confuses me is surely the fridge would be cold, too cold, if this was failing (unless airflow is blocked very quickly due to the ice up of the evap).
Thanks again – mystified as apart from the heater and cover (which has been re-sealed) pretty much all has been changed. Bottom central bar still showing but I understand this is not a ‘live’ report merely an indication of a fault occuring (I heard it resets after a while??)
July 1, 2007 at 5:37 am #219071admin
KeymasterRe: samsung rs21 blues
The evaperator cover that is on your appliance is a totally different one than a standard RS21 and its not a common fault.
I have never had to change a fan motor.
The evaperator cover that is fitted to your appliance has a heater,electronic closing duct,fa & motor assembly.
If your defrost heater and thermal fuse & defrost sensor are working correctly as you say then this evaperator cover will need to be changed.
The insulation on this panel cannot just be changed due to the components inside it and the functions it carries out.
this is avilable from myself r600a@hotmail.com
Bryan
July 1, 2007 at 2:36 pm #219072samsungblue
OK, having now replaced three parts without success I am going to replace the drain heater and cover assembly – I have just noticed what looks like another heater fed within the evaporator coils, it is powered by the mid of the three sockets, same as drain heater via a splitting block – is this a second heater as well as the drain heater?
July 1, 2007 at 2:42 pm #219073admin
The drain heater unless it has made a solid block of ice at the bottom channel will NOT be faulty therefor will NOT require changing.
There is a defrost heater on the evaperator assembly to which i beleive you are refering to,Yes this may be faulty.
Bryan
July 1, 2007 at 9:35 pm #219074samsungblue
Thanks Bryan
to clarify for others with the same problem…
there is not solid ice in the drain so as Bryan says it’s probably not a drain heater fault (there is a little ice in the channels that slope to the hole though).
The evaporator ices up in about an hour. Main suspect now the evaporator heater. (Or could this be a fault on the pcb not triggering a defrost cycle?)
My RS21 JGRS (seems a fairly rare model – I think the letters at the end refer to the painted finish etc). as above has a special servo flap near the top inside the evaporator cover as well as the fan as this may be faulty too so I am advised to get a new cover assembly (fan already changed as above).
If anyone thinks I’m way off please shout – the milks been warm for a week now!
July 1, 2007 at 9:43 pm #219075helo_75
Participanti do have to say (and ive been very vocal about samsung problems, as we all know) that the pcb rarely fails on samsungs
one thing samsung do well is electronics
a quick check with a good multimeter will tell you if the heater is faulty..
good luck
July 1, 2007 at 9:49 pm #219076samsungblue
what reading would I and other with this problem be looking for? total open/closed or a certain resistance? by the way guys the compressor seems to be running constantly.
July 1, 2007 at 10:25 pm #219077helo_75
Participantit will if somethings not telling it to switch off!! sensor? maybe?
hmm, youve changed that
if youve changed everything else then its gotta be the heater, which will be open circuit if its faulty
have you changed the evap cover?
July 1, 2007 at 10:44 pm #219078samsungblue
so far….
new fan
new sensor
new thermal fuse
not changed the evap cover yet but my money is on the defrost heater cos of the ice up after an hour. need to source the right one (for RS21 JGRS) I think the four last letters are just the cabinet finish??? The one for RS21 DCNS looks like the one???
the evap cover has the electronic duct flap and fan (fan changed already) -
