A couple of days ago the flap which closes off the ice dispenser has stuck open. This is causing the freezer to frost up inside. Nothing seems to be causing it to stay open. Does anyone know what i need to do. The 2 year warrantee ended 6 months ago.
thanks for any suggestions
The plastic clip that holds it might be broken or the solenoid mechanisim might be goosed , If any of the locators that hold the components in place are broken then a new freezer door is the only answer .
