Re: Samsung rs21 defrost heater ohms
Hello,
If it is the yellow evap sensor you are talking about, the white ones were prone to water ingress. Then giving out-if-range readings to the control module.
The heaters are around 5 Ohms. and there is a newer modified version of that too now. I have them in-stock, please PM me if you want one.
It sounds to me as if the thermistor could be faulty. Set it to a forced defrost and then see if the heater starts to warm up. Often what happens is the sensor is faulty after a 30-90 seconds you will hear a click from the rear board and the power to the heater will be cut. Also have the sensor from stock.
Let me know
TM
