SAMSUNG RS21 DEFROST PROBLEM
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum SAMSUNG RS21 DEFROST PROBLEM
  • #91594
    Babyblog
    i’ve read some forums on here, but can’t answer this problem. So my fridge is keeping cool, but the back panel is icing up. The fault code is for “Refrigeration Defrost Fault”.
    What is this more likely to be?
    Do i need a new defrost heater? Defrost sensor? Or Thermal sensor?
    I don’t want to just change everything if there’s something which is most likely to be at fault. The sensor is the new yellow one with black bullet type end which i’ve seen on forums saying that’s the one it should be – Samsung did a fix on this before.
    thanks
    #448678
    Re: SAMSUNG RS21 DEFROST PROBLEM
    On RS21’s the only way to be sure you kill the problem is to change the back panel and sensor/s.
    Babyblog
    Many thanks for the advice..
    Think that’s the way forward then
