Ok guys im sick of goin to these fridges , test everything nothing wrong , defrost the evap and fan housing and just for good measure change the defrost sensor but nooo that wont cure it are these panels so crap that the fan and water bottles start icing up again within a week aaaaggghh
Then your not testing them correctly. There’s masses of information on the forum of how to test,read the fault codes and what to change. And the panels also come with instructions also.
Re: samsung rs21 dgrs, dcns fan icing , water bottle frozen
I haven’t seen an error code on one of these in a long time, unless you forget to connect some component , is there a diagnostic test for these besides the initial start up and as for the tech manual that was translated by a 4 yr old !
