Samsung RS21 drain hole
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RS21 drain hole
  • #30596
    stevedrink
    Where does the fridge drain hole run to on these fridges, mine was blocked with ice but it doesn’t seem to want to clear ?
    Cheers
    #227753
    Re: Samsung RS21 drain hole
    if your drain hole is blocked with ice then you will need to replace the drain heater,Switch off for 24 hours before doing so to allow the drain to clear and allow the old heater to be removed.
    Bryan
    #227754
    stevedrink
    thanks, can you point me to the correct part, might as well change the evap cover because i’ve had it off 3 times to clear from fan.
    no fault codes when i press the two buttons.
    Ta
    Steve
    #227755
    Hi steve
    e-mail me at r600a@hotmail.com and I can supply both.
    bryan
