Samsung RS21 Error code help
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung RS21 Error code help
  • #77936
    asp11
    I’ve got an error code chart for a Samsung SRS2028 which I’m hoping will be the same for all the samsung US style appliances?????
    The fault I have is a line on the top right digit in the fridge display area which indicates an error with the ICE MAKER SENSER — After checking the senser, which is has 2 white wires on the ice maker plug I found it to be open curcuit. Am I to assume that this is actually the fault or is it meant to be open curcuit?
    The 2 white wires go directly to the pcb at the rear of the machine and they are fine.
    Any help please?
    #403957
    SAMURI
    Re: Samsung RS21 Error code help
    The sensor wires will be broken near the sensor, you can solder and insulate them or buy a new sensor.
    Bob
