RS21WCNS S/N855642BPB00142K
This fridge freezer had shut down and defrosted. I tested everything in fridge and freezer (heaters thermal, fuses, sensors, fans)all tested ok. Visually checked power board at back every thing looked ok, fuses fine. All that showed on the display was one dash flashing on the fridge tempreture digits.
If you think of the digits as looking like 88 it was the bottom right vertical line on the second 8 that was flashing.What does this mean? The machine kicked into life after reset but i fear it may cut out again. Could not find any of the error codes in known error codes.
Subs
