Samsung RS21 Fridge freezer Power Freeze problem
Home Forums Public Support Forums General Enquiries And Questions Samsung RS21 Fridge freezer Power Freeze problem
Viewing 1 post (of 1 total)
  • #103092
    JP00712
    Hi​​​
    The power freeze keeps switching on and off constantly by itself. Each time it does so it beeps, same as if I were to press the button myself so is annoying.
    The fridge freezer itself works fine, both the fridge and freezer at correct temperature. Door seals all good.
    Upon doing a panel diagnostic by pressing the 2 buttons on the front panel, it shows there is a error 12, Con Fan Error.
    Does anyone know what this relates to? It suggests to replace the condenser fan at the back of the fridge, however I can see online that this is usually to fix a warm fridge or freezer.
    or is it worth replacing the condenser fan anyway?
    But as I say the fridge and freezer are working fine. Does anyone have an idea how to fix this constant beeping due to power freeze switching itself on and off?
    Many thanks.
