samsung rs21 fridge temperature
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum samsung rs21 fridge temperature
  • #62563
    terkal
    Hi guys, can anyone tell me how precise the diagnostics are on the rs21 fridge/freezer.I’ve had the visit to install the clip etc about a year 1/2 ago but now the temperature on the fridge has started playing up..I have defrosted the fridge side,a lot of ice behind the panel and it worked for a few days..the diagnostics show No3 r-def-sensor,is it a case of just replacing it ❓
    #350474
    richardengineer
    Re: samsung rs21 fridge temperature
    terkal wrote:Hi guys, can anyone tell me how precise the diagnostics are on the rs21 fridge/freezer.I’ve had the visit to install the clip etc about a year 1/2 ago but now the temperature on the fridge has started playing up..I have defrosted the fridge side,a lot of ice behind the panel and it worked for a few days..the diagnostics show No3 r-def-sensor,is it a case of just replacing it ❓
    Hi you need to get to the heaters behibe the panel poss one or more is o/c did you fit a new rear panel same time as the clip?
    #350475
    terkal
    Hi, I thought they did fit a new panel but the more I think about it the less sure I am(it’s an age thing!).I took the panel off when I done the defrost..it does have the black cap defrost sensor and I completly cleared the ice..even then when I applied the diagnostics it showed the R-DEF-SENSOR error indicator.
    #350476
    fo3oz
    Self diagnostics are normally pretty reliable. It’s what they can’t detect that causes problems. But what they can’t detect is easily diagnosed with a multimeter
    #350477
    Self diagnostics are normally pretty reliable. It’s what they can’t detect that causes problems. But what they can’t detect is easily diagnosed with a multimeter/quote]
    Not quite right on the samsung models..The sensor reading with a multi tester or anything else id a waste of time as they don’t give continued constant readings.Also the correct readings are only available if tested at a continued constant ambient temperature.
    The defrost sensor is changed at all points where there is a defrost fault full stop..
    Bryan
    #350478
    fo3oz
    sensors can be tested with a multimeter, you just use volts while the fridge in on, rather than resistance with the fridge off.
    Volts are what the controller reads, and that’s all that matters.
    Volts good, then the fridge will work.
