Hi All,
I have been going through the forum over the last few days trying to work out a couple of problems with the fridge section. I am guessing I am going to be told it is the Evaporator cover as the bottom bar illuminates on the diagnosis and the fridge is warm at top and cool at bottom. I had a check behind the cover but it wasn’t iced up like many others on the forum. Also, the lcd temp display doesn’t read the correct temp and needs to be turned on and off to display the correct temp. Before I noticed the problem (took me a while as my beer was always cold as it’s kept at the bottom) the temp was reading 4 which was obviously wrong.
I am looking for a bit of guidance as this is my second Samsung side by side as the last one was replaced on warranty after the freezer died and after the engineers changing virtually every part over a 4 month period they gave up.
Thanks in advance,
Andrew
