Samsung RS21 NCSV
  • #19295
    humphrey99
    I wonder if anyone can help, the repair man I called in couldn’t find the root of the problem. I bought this American side by side about two years ago and have not had any problems until now.
    The fan ices up but all the air vents are clear, and it’s not to close to the wall. If I take the cover off the fan and de ice it, all is well for a couple of days. If I leave the ice on the fan it stops working and sounds like a big cat with bad wind….very growly! Has anyone had the same problem?
    #182561
    Re: Samsung RS21 NCSV
    you will need at least the main evaperator cover which i hold in stock,the polastyrene has a tendency to soak up the water and swell which is what the fan hits and you can hear.
    if you want us to supply then e-mailme at
    r600a@hotmail.com
    bryan
