Samsung RS21 NGRS Side by Side Fridge fault
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RS21 NGRS Side by Side Fridge fault
  • #35507
    CityFan
    I’ve an 18 month old Samsung american style side by side fridge freezer, RS21 NGRS twin cooling version. The freezer temp is OK but the Fridge is high. When I looked inside at the bottom it was frosted up. If you turn it off you get an error code on the fridge side indicator… the right hand 8 bottom led is lit, then goes off. I can’t hear a fan working. I read some of the other topics on the forum which indicate a number of possibles… the fan being one of them.. Is the fan the sole issue, or do I typically need to test any other components ?
    Regards
    #246848
    It’s still under warranty at that age so I’d strongly advise you call Samsung. Messing about with it could invalidate the warranty.
    HTH
    Re: Samsung RS21 NGRS Side by Side Fridge fault
    If its 18 months old then you need to call 0870 7267864 as it is still under warranty.
    you will need to have your receipt to hand and also your full model number and serial number.
    Bryan
    #246850
    CityFan
    Thanks folks, didn’t realise it had a 2 year warrantee ! Booked an engineer.
