Samsung RS21 no or occasional fridge fan.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung RS21 no or occasional fridge fan.
  • #66266
    delahart
    Have been battling with a Samsung RS21FGRS for several weeks! Initially fridge iced up and defrost heater o/c. Fitted heater and sensors supplied with it but not the gas pipes. Left fot customer advising OK now. However didn’t cool and found fan not working. Light switch seems OK and fan motor OK as works in cooling fan connection, so ordered board. Fitted board and ran for about 30 mins and fan seemed to operate after switching light switch. Advised customer OK. Still not cool enough and my lad checked again and fan only seems to run occasionally. We fitted a fridge sensor but not sure if the right one as Connect part came up as SAMDA3210105G but description on the packet was icemaker sensor! Is it the same or is that the wrong one and probable fault. It has a much longer lead than the original. Not positive that it is the sensor. Freezer fine.
    ANY ideas or info gratefully recieved. I do not have diagnostics for this.
    Cheers,
    Delahart.
    #363653
    The correct defrost sensor ends with 13h or maybe even k now. I have you changed the evap cover?.
    I’ve also found bad connections on the multiplug at the pcb due to corrosion.
    Bryan
    #363654
    delahart
    Re: Samsung RS21 no or occasional fridge fan.
    Thanks for the reply Bryan.
    It has a new defrost sensor supplied with the heater. It is the fridge sensor by the light that I was not sure about. The plugs on the board look good. How would the evaporator cover affect the fan operation?
    Delahart.
    #363655
    Cras
    ive had two this year with intermitant fridge fan motor problems changed fan motors on both without any further problems ,the evporator covers i have ordered in the past have come with with new fan motors fitted ,hope thats some help 🙂
    #363656
    fo3oz
    Came across this twice myself, it’s the fan motor. It usually runs for 5 min then cuts out.
    It doesn’t pick it up on start up diagnostics, but if you run diagnostic mode it will probably come up with the LED for fan fault.
    #363657
    delahart
    Hi all,
    Thanks for advice.
    Have changed fan motor and cover as an assembly and so far seems to be OK!
    Will post again if problem persists.
    Del.
