Samsung RS21 problems – need an error code deciphered…
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RS21 problems – need an error code deciphered…
  • #27552
    Vincepbell
    Hi gents,
    Having the usual defrost issues with my RS21. I replaced the fridge sensor recently which helped, but after a few days a new error code appeared.
    At first it was just the middle bar on the fridge side, I was told I needed a new defrost heater, which I stupidly paid the guy £58 pounds for (Tony Clifton @ Airkool), and he’s never sent it and now stopped answering my text messages. 🙁
    Anyway, got a little off topic there!
    The error code is currently the middle and top bars on the fridge side. I’ve already replaced the fridge sensor and the evaporator cover. What do I need to do next? Do I need the defrost heater, and if so, is this the correct one: http://shop.ukwhitegoods.co.uk/product_ … ts_id=1067 ?
    Cheers guys!
    Vince.
    #214658
    Vincepbell
    Re: Samsung RS21 problems – need an error code deciphered…
    Hey again,
    Just went back in to the kitchen and noticed that the fridge temp is now actually flashing.
    What on earth does that mean?
    Cheers,
    Vince.
    #214659
    Nutty
    Hey Vince
    When the temperature and the lights are flashing it means that it is not at the correct temperature and is probably getting warm and not cooling at all
    Nutty
    #214660
    3stars
    Hi Vince,
    The first error code you have means that the ref section is taking longer than 80 minutes to complete a defrost. This will indicte a fault with either the Thermal fuse, defrost heater or the defrost sensor in the ref section. Your new error code is the ice maker sensor, this can be repaced as a complete ice maker unit. If you switch the ice maker off on the control panel this error code should disappear.
    #214661
    Vincepbell
    Thanks for the info!
    Thats very strange, however, as the ice maker seems to be working perfectly still?
    Could you confirm for me that the link I gave is the correct defrost heater? It’s the only part I haven’t replaced yet, but I’m not sure thats the right one.
    Thanks,
    Vince.
    #214662
    porschejohn
    Hi Vince
    I am having the same problem, have you replaced the defrost heater yet and has it cured your problem? Also, when I press and hold the top 2 buttons the middle light comes on on my fridge, is this how you accessed your error code?
    John
    #214663
    Vincepbell
    Hey,
    I fitted the new defrost heater, and the fridge is working normally for now, but the error code has returned.
    Middle bar on the fridge side is lit.
    Not sure what to replace at this point…..
    Cheers,
    Vince.
    #214664
    Simon46
    Did you meter the plugs out resistance wise?. Unplug appliance first from wall socket.
    Regards
    S.
    #214665
    Hi vince
    E-mail reply sent
    bryan
