Samsung RS21 sxs defrosting.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung RS21 sxs defrosting.
  • #71745
    bandit2510
    Had a call to one of these replaced defrost sensor and thermal fuse due to ice build-up. Now freezer runs for 8-12 hours then alarms and flashing on freezer display. Any common problems with the freezer side?
    #382150
    bryan-206
    Re: Samsung RS21 sxs defrosting.
    Freezer light switch…. Does the light switch off. This is the only thing that will cause an audible alarm.
    #382151
    bandit2510
    Sorry Bryan the alarm does not sound,added that by mistake. Just the display flashes.
    #382152
    bryan-206
    Then most likely door has been left open. Freezer side very very rarely goes wrong. Vents at rear of freezer will have frost in and evap will be clear. Defrost and reboot.
    #382153
    BobHope
    what does the display flash ?.
    Bob.
    #382154
    bandit2510
    According to the customer its just flashing on/off.
    #382155
    funkyboogy
    ask customer to press 2 top buttons together for 10 seconds – display will go blank and if there’s any errors stored the digital segments will flash – ask customer to record what segment is flashing – this is a fault code ..
    freezer dont normaly go on these , and poss could be over ice like prev poster defrost and reboot … you can get the defo sensor going in freezer and fan .. but thats about it ..
    ally
