Samsung RS21 temperature rising after repair
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RS21 temperature rising after repair
  • #90200
    DRW
    Am I right to panic, or is this normal?
    I’ve just fitted a full repair kit to my ancient Samsung RS21, following instructions to the letter.
    Since switching it back on, the fridge temperature was rising rapidly – up to 30 – until I switched it to Power Cool. It’s now falling slowly, but is this normal or have I done something wrong?
    (The reason I fitted the repair kit was because it was tripping the RCD.)
    #444020
    Re: Samsung RS21 temperature rising after repair
    How long ago did you fit it ?. Its takes more than 8 hrs to get down to temperature .Did you fit ALL the parts and in the correct position ?.
    Bryan
    #444021
    DRW
    Hi Bryan,
    Thank you for the rapid reply. I fitted it this evening.
    My worry wasn’t so much that the temperature wasn’t going down, it’s that it was rocketing. When I plugged in the fridge the readout said 20, but within five minutes it was up to 30.
    I’m pretty confident I fitted all the parts, in the correct positions.
    Which sensor controls the temperature readout?
    #444022
    DRW
    It’s down to 6 now on the display, by the way, after being on Power Cool.
    In contrast, the freezer (on Power Cool) is still on 8.
    #444023
    LothianDomestics
    Spectator
    What was the original fault that caused you to order/fit parts?
    If you open both doors, is the section in the middle of the fridge and freezer hot to the touch?
    #444024
    DRW
    The middle section is cool to the touch.
    The original fault was that the unit was tripping out the RCD. The water dispenser had stopped working a while ago, and I’d thought nothing of it. But when I dismantled the fridge, everything was iced up.
    One concern is that the panel that covers the heater had a melted section in the plastic.
    #444025
    You’ll find that it’s back to normal in the morning..Stop opening the door.
    Bryan
    #444026
    DRW
    Thank you for the reassurance. Seeing the melted plastic had me worried.
