Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › samsung rs21 water bottle replaced
- This topic has 8 replies, 5 voices, and was last updated 8 years, 3 months ago by
slyp98.
January 8, 2018 at 11:11 am #93002
slyp98
ParticipantHi all HNY,, i swapped the water bottle in this american style F/F but now it is only half full of water and when the flap is released water keeps flowing for 5 seconds , ive checked the solenoid the hoses , no leaks anywhere , dunno what im doing wrong
January 8, 2018 at 12:30 pm #452859SAMURI
ParticipantRe: samsung rs21 water bottle replaced
If you replaced the water tank with the pipes the correct way around and no leaks then it is just an air lock in the system.
You just need to draw of several litres of water to clear the air lock.
Bob
January 8, 2018 at 6:19 pm #452860slyp98
Hi Bob , i thought that but i filled 6 litres of water into a bowl no change
January 8, 2018 at 7:18 pm #452861BobHope
You have fitted the water pipes the wrong way around. the air trapped in the tank is compressed by the water pressure and when the solenoid valve closes the air expands and continues to push the water out.
bob.
January 8, 2018 at 7:51 pm #452862slyp98
I tried that too mate thanks neway
January 8, 2018 at 8:23 pm #452863bazza500
Fitted the bottle upside down?
January 8, 2018 at 9:15 pm #452864slyp98
yeah i dunno it seems ive tried all of the above , maybe im missing something but the hoses actually relate to where they need to be routed , actually one of the hoses was v. long i cut at least 500mm off it , it does seem like an airlock as stated , i can see an air space at the top gallery , its always there when the bottle fills and you shut the flap killing the solenoid , the water keeps flowing leaving the air gap at the complete top gallery , i dunno
January 9, 2018 at 6:34 pm #452865BobHope
The water should enter the tank from the bottom pipe.
bob.
January 18, 2018 at 12:04 pm #452866smartin
as bob said water bottle fitted wrong way round, remove put fit pipes other way round and it will work.
