Re: Samsung RS21 water container
one of the pipes runs from fridge to bottom of frz door , and the other runs down through fridge comp to water valve at rear
Best way to do this
1 cut water pipes in fridge & unscrew old bottle
2 pull old pipe through at kick plate
3 screw new bottle back on , and feed new front side pipe so it comes out at kick plate- connect back up under door
( check end of old pipe at connector as there is a little plastic end that you need to take of old pipe and fit onto new one) ..
4 take backplate of and disconnect pipe at water valve
5 pull old pipe through
6 feed new pipe through from inside fridge..
7 reconnect at rear water valve…
job done
a bit tricky but should only take 30 mins max…a
ally
