Samsung RS21DCNS Fault Code
Home Forums Public Support Forums General Enquiries And Questions Samsung RS21DCNS Fault Code
  • #75500
    ppreget
    Where can I find the list of all fault codes generated by pressing simultaneously on the power freeze and power fridge buttons?
    I currently have a fault on the freezer side bottom right bar.
    Any help would be much appreciated.
    #395128
    Re: Samsung RS21DCNS Fault Code
    http://www.ukwhitegoods.co.uk/help/faul … ezers.html
    ppreget
    Brilliant, thanks kwatt.
    Looks like I have code 10: :F DEF ERROR, what does this stand for and which part do I need to replace?
    #395130
    Sound like it’s telling you there’s an error on the defrost circuit. You need to work out why.
    ppreget
    ok, was hoping for a bit more help as I could see the defrost word in the error code.
    Have found other posts talking about continuity test on fuse and ohms readings on other two connectors. My bottom connector (yellow cables with white sensor – defrost thermal sensor) reads around 300 ohms constant no matter the temperature so I assume this is faulty and have now ordered a replacement from this site.
    Waiting for the part now…
    #395132
    We can supply a kit with all the parts needed to repair the fridge problems.
    Bryan samsung@ffrservices.co.uk
