samsung rs21dcns, fridge side freezing evap ,
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries samsung rs21dcns, fridge side freezing evap ,
  • #69688
    slyp98
    hi all , went to this a month ago , freezer ok fridge evap frozen , fan frozen over , water bottle frozen also , checked all components all checked out ok , but the thermal fuse was blown , fitted new one and all was fine until yesterday , customer came home to find fridge off , rcd had tripped and fridge is back to the initial state any ideas??
    #375688
    machineman
    Re: samsung rsh21dcns, fridge side freezing evap ,
    defrost htr, sensor, gutter htr, all suspect on these.There also should be a protective fuse mod in with the pcb
    Theres a problem with your model number. Is it a RSH1 or a RS21 ?
    Did you also check that the heater’s was working and NO damage. Also did you put the thermal fuse in the correct position ?.
    Bryan
    #375690
    slyp98
    sorry guys , its an rs21dcns , the heater is fine , i meggered everything no problems when i opened the evap cover the coils were clear of ice but there was a block below the coils on top of the gutter heater and it was clear ice and the sides of the evap and top were white ice , i can only suspect no power coming to the gutter heater ,the thermal fuse has connectors , i dont think it can be put the wrong way around ?
    #375691
    machineman
    Check the gutter htr and make sure the gutter hole is clear by pouring hot water down it ,the hole is under the centre of the htr and goes of to the left
    I use a long small hose so you can suck and blow the water into the hole .Nice ,it takes ages
    Replace the drain heater then ? Did you separate the 2 heaters ?,Did you change the defrost sensor ?
    Bryan
    #375693
    slyp98
    Re: samsung rs21dcns, fridge side freezing evap ,
    yeah Bryan i checked them both seperately and meggered em too , and changed the sensor also , i didnt have a drain heater to replace it but i was sure it was fine
    #375694
    machineman
    it could just be blocked from previous visit
    slyp98
    nah defo not blocked , and not this time after i left either , i poured water down until i heard it in the catch tank
    #375696
    bryan-206
    By correct position I think he refers to its location. Ie behind the evap or between the evap and defrost heater. Thermal fuse would require sensor replacement also.
    I am here: http://tapatalk.com/map.php?5o3htx
    Life’s a bitch ain’t it!
    #375697
    slyp98
    ok yeah its located r/h side of evap cable tied to the evap coils
