Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung RS21DCNS main pcb clicking/chattering
- This topic has 8 replies, 6 voices, and was last updated 13 years, 9 months ago by
rasperer.
July 2, 2012 at 8:27 pm #70258
rasperer
ParticipantHave got a Samsung RS21DCNS FRIDGE/FREEZER that works perfectly fine,achieves temperature in both fridge and freezer sections but once it has achieved its set point and the compressor knocks off,the main pcb emits clicking sound(possible relay chattering on board).Also does this when in itially puting power onto cabinet during time delay before compressor kicks in.Before forking out for a potentially expensive circuit board are there any underlying issues that can cause this or somebody who can repair the board(replace faulty relay if necessary)Any views or thoughts as to cause of problem would be appreciated,thanks.
July 2, 2012 at 9:02 pm #377606Allsorts
ParticipantRe: Samsung RS21DCNS main pcb clicking/chattering
*Warning* PCB repairs require professional attention … Not repairing correctly can cause fires or electric shocks.
This sounds similar to a few Whirlpool issues… Capacitors go weak, not creating enough power for relays to operate properly…
If the power going into the relay is low the capacitor that is inline before the relay may be the cause of the fault.
UKW member R600 is a Samsung expert who could possibly supply you with the necessary knowledge or parts
July 2, 2012 at 9:15 pm #377607admin
KeymasterRe: Samsung RS21DCNS main pcb clicking/chattering
This fault isn’t a common one and in 10 yrs i haven’t seen one do this.Where a bouts in the country are you as it sounds like you will need an engineer.IF you want to change the pcb yourself then yes I do have then in stock.
Bryan
October 5, 2012 at 5:12 pm #377608rasperer
Hi,sorry for the delay in getting back and appreciate all your input.Would be most grateful if you could supply me with a quote/price for a relacement board Bryan.Am a refrigeration engineer myself so no problem regards replacing myself.Thanks once again. smc73@live.co.uk
October 6, 2012 at 7:30 am #377609bryan-206
Does your machine have ice maker?
October 8, 2012 at 8:27 pm #377610rasperer
Yes,the cabinet is equipped with an ice maker.PCB ID no:DA41-00188A ET-R600a VER 1.2 Dont know whether this helps any.
October 22, 2012 at 1:53 pm #377611bryan-206
Did you get a price for this board?
January 30, 2021 at 8:11 pm #377612Baz harper
ParticipantI have similar problem with my Samsung American style fridge freezer model rsj1jemh, pcb on top of fridge clicking noise ,now nothing working i take it its the relay but not sure.
January 31, 2021 at 9:34 am #377613electrofix
Moderatorthe noise will probably be a relay as its the only mechanical device on the board but its unlikely to be the relay causing the fault
