Samsung RS21DCNS Water Dispenser Dripping
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RS21DCNS Water Dispenser Dripping
  • #30585
    montescalion
    The first time I used the water dispenser after changing the filter it spluttered quite a lot and then took a few seconds to stop dispensing water after I released the lever. It now dispenses water correctly but trickles for a second or so after I release the lever and drips continuously (albeit very slowly).
    Has anyone else experienced this problem?
    #227710
    alf2007
    Re: Samsung RS21DCNS Water Dispenser Dripping
    i to have this fault ,have had 6 visits by comet fitters & have had a number of parts changed now & the problem is now much worse.after filling my glass the water still runs for 8-10 seconds .if i knew what the cause was i would fix it myself
    #227711
    rickard
    loose connection on the water pipe tighten all connections and that should cure it
    #227712
    alf2007
    thanks for that ,off to work now but i’ll get on it tomorrow & let you know how i get on 😀
    #227713
    alf2007
    😀 😀 😀 all sorted ,it was the in line connection under the doors,sealed it up with bath sealent & no drips since .thanks very much for the advice
