Samsung RS21DCNS1 Not Working – Both Fridge & Freezer
Home Forums Public Support Forums General Enquiries And Questions Samsung RS21DCNS1 Not Working – Both Fridge & Freezer
  • #66923
    pca66
    Would really appreciate some guidance with regard to this matter.
    we have owned this fridge/freezer since new since 2005
    I am aware of the legacy problems with the cooling fan freezing and this was replaced in April 2011 by a recommended Samsung engineer.
    I have removed the cooling fan panel today and cannot find any evidence of ice that might need to be defrosted and everything looked clean and in order
    I unplugged the fridge/freezer for 12 hours today to see if that sorted things out, NO LUCK.
    I have also tried to use the self diagnosis, this just flashes 88 on both sides, so not quite sure what this means.
    Could it be the motor that’s gone or a problem with the gas.
    Either way is this something that can be fixed at a reasonable cost, or is there something I’m missing
    Any advice would be greatly appreciated
    #365639
    Is there any dashes on the front panel ? .
    Any noise ? .
    Bryan
    #365640
    pca66
    Re: Samsung RS21DCNS1 Not Working – Both Fridge & Freezer
    The panel shows temperature readings of 18 for freezer and 16 for fridge. When i press the buttons the following appears on the front panel -88 & 88
    There is no noise whatsoever
    Appreciate your help
    #365641
    mjjuk
    Disconnect the appliance
    Reconnect
    Quickly press and hold ‘power cool’ & ‘power freeze’ buttons for 6 seconds
    Note where the dashes appear these are error codes
    The dash should be either in the freezer side or fridge side
