Samsung RS21DCSV
  • #29642
    clivejameson
    Part number please for the fridge evap cover and is this the ‘improved’ one with fan motor etc?
    #223956
    Re: Samsung RS21DCSV
    Dat one?
    http://shop.ukwhitegoods.co.uk/product_ … ts_id=1082
    clivejameson
    Well i’m wondering because Connect show it at around 11 quid 😯
    I’m assuming this is just a simple plastic cover on Connect and not ‘the works’? (i realise they’re not your favourite supplier Chris 😉 )
    #223958
    funkyboogy
    latest part no from samsung
    DA97-05290Q WITHOUT COOLZONE
    DA97-05290W WITH COOLZONE
    DEFROST SENSOR DA32-00006U (SENSOR NOW BLACK IN COLOUR)
    THERMAL FUSE DA47-00095E
    YOU CAN TELL IF NEW COVER ASSY IS MODIFIED IF YOU GET A LEAFLET WITH IT, CONTAINING A SMALL METAL CLIP..(TRANSFERS HEAT FROM EVAP TO COVER ASSY)
    IF NOT , ITS NOT THE LATEST PART..
    ALSO WORTH CHECKING HEATER ARE WORKING…
    #223959
    clivejameson
    Cheers FB
    #223960
    clivejameson
    Defrost heater was fine during time of replacing the evap cover…now it’s gone o/c 😕
    Can the fridge defrost heater be replaced without the evapoartor, and if so does anyone have the part number please?
    #223961
    Simon46
    Clive the heater is unclipped from new Evap by bending fins slightly. Then fitted to old Evap in same way.
    Regards
    Simon
    #223962
    funkyboogy
    PART NO FOR EVAP..
    DA96-00013T,
    unfortunately you have to get whole evap , and then remove heater unit from it…
    ally
    #223963
    clivejameson
    Ok thanks Ally 😉
