Does anyone know how to force the defrost cycle from the control panel i have checked the heaters and i am getting good readings, the thermal fuses are ok, but the fridge and the freezer freeze up after about 4 weeks, i want to check that there is voltage getting to the heaters but cannot find how to get the voltage on, as i want to check if the board is doing anything?
