Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Samsung RS21DLMR
- This topic has 11 replies, 6 voices, and was last updated 17 years ago by
Kez.
March 13, 2009 at 10:26 am #44194
Kez
ParticipantThis Samsung American style fridge freezer went pop and now has one line on the display. Nothing running. Checked rear board and no visible signs of damage. Any ideas?
March 13, 2009 at 2:08 pm #280124admin
KeymasterRe: Samsung RS21DLMR
Which line ?
Bryan
March 13, 2009 at 2:20 pm #280125Kez
ParticipantRe: Samsung RS21DLMR
its the top line of the 2nd “8” on the fridge temperature and its flashing. Kez
March 13, 2009 at 8:08 pm #280126lerch
I/M sensor connector missing, contact failure, electric wire cut, short-circuit, I/Msensor failure.
March 13, 2009 at 9:01 pm #280127funkyboogy
what lerch is trying to say is,,
change the ice maker sensor.. sits underneath the ice tray but you have to order ice ice tray motor assy to get sensor..
you can cut and join sensor if you find where wires have broke.
you might be thinking ice maker sensor would cause whole app to fail , but it does…sounds silly but unfortunately its true
ally
March 14, 2009 at 6:15 pm #280128lerch
LOL I was very tired so just paste and cut. 😀
March 16, 2009 at 5:28 pm #280129Kez
Thanks for your advice. The i/m sensor is showing as a separate part on connect 5031680996791 – is this the same part that comes with the ice maker assy?
March 16, 2009 at 9:50 pm #280130funkyboogy
dont know tbh,
ive been used to fitting whole ice maker tray assy,
allyMarch 17, 2009 at 10:20 am #280131TeeMyob
Kez wrote:Thanks for your advice. The i/m sensor is showing as a separate part on connect 5031680996791 – is this the same part that comes with the ice maker assy?
That part looks different to me!March 26, 2009 at 2:40 pm #280132Kez
Have fitted ice maker assy which has now cured the original fault, thank you. However, now the freezer is only maintaining between -2 and -4. Fridge is maintaining 3 degs. Just short of gas, following being off for a while or something else?
March 27, 2009 at 9:34 am #280133Kez
Engineer went back out this morning – regfrigerating correctly, internal fans running, not short of gas, BUT the condensor fan motor is not running. Ice maker assy has cured original fault but the condensor fan makes no more than 1/4 turn and then stops, the fan was running when the engineer left after fitting the ice maker assy and the fan is not seized so dont think it’s the fan thats faulty. Any ideas?
March 27, 2009 at 5:09 pm #280134expertcat
Participantit depends on room temp if it needs to run the fan or not.
