Samsung RS21DNSM freezer warm, fridge cold
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RS21DNSM freezer warm, fridge cold
  • #102981
    Thorvald
    Hello!
    New member with a for me complicated problem..
    The fridge part function as normal, had it set to 3 degrees, and it works flawless.
    The freezer on the other hand, stays at room temperature.
    As far as I have testet, everything works.
    Sensors have been tested to the correct ohm, fan spins, no ice build up, compressor kicks on, condenser fan spins, capacitor at the correct value, door switch does it’s thing, no codes stored when checked.
    In my simple world, if the compressor are bad, or the sytem has a leak, it should not cool the fridge part, and the freezer should at least drop to the same temp as the fridge befor giving up.
    Anyone with some ideas to what I should check next?
    #491333
    Thorvald
    No one? I hope to save this from the scrap
