Samsung RS21FCNS Dispenser Cover Removal
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RS21FCNS Dispenser Cover Removal
  • #68181
    Tricky Dicky
    Hi all
    I need to remove the dispenser cover to access the Ice-route gasket which has become detached and is causing an ice build-up in the dispensing chute. Looking at an exploded diagram of the assembly there appear to be 2 clips/lugs on the bottom edge and what I think is a strip of double sided adhesive foam strip near the top. If this is correct I presume I need to work some sort thin non-metal tool in from the top to break the adhesion of the foam/tape and pull downward and away from the door to detach it. To re-fix it I assume the adhesive strip needs to be replaced before re-attachment. Could anyone familiar with this model advise me accordingly.
    Thanks in anticipation
    Richard
    #370122
    Nooo not from the top.
    A blunt dinner knife size lever at the bottom of the cover there is 2 insert points, gently lever towards you and unclip bottom to the sides equally and work upwards. Just so happens that’s what I’m working on in the workshop now..
    Bryan
    #370123
    Tricky Dicky
    Re: Samsung RS21FCNS Dispenser Cover Removal
    Thanks for that super fast reply r600a
    Richard
    #370124
    Tricky Dicky
    Job done! Just have to wait for it to produce some ice cubes but the mechanism all seems to be working. That’s saved £95, the last fault cost me that, turned out to be a loose wire it took the engineer longer to fill out the docket than do the repair. His tongue in cheek parting comment was “at least you did not have to fork out for spare parts”
    Brilliant help! Thanks again r600a
    Richard
