SAMSUNG RS21FCSV FRIDGE/FREEZER
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum SAMSUNG RS21FCSV FRIDGE/FREEZER
  • #70091
    ali1
    HI.I have changed the defrost sensor but the evaporator annnd fan ices up.heater ok sensors ok.any ideas?i dont want to change cover and have the same problem.any help will be welcomed.ali
    #376966
    Re: SAMSUNG RS21FCSV FRIDGE/FREEZER
    Which heater did you check ? thermal fuse ?,You will need to change the evap cover (panel)
    Bryan
    #376967
    ali1
    hi bryan.thanks for the quick response.checke defrost heater,themal fuse,all ok(close circuit)changed sensor.(defrost sensor).ill change the cover and see.update u in due course.r u able to tell me why the cover change makes a difference cause is only plastic cover and the insulation seems to be ok?thanks again .Ali
