Samsung RS21FCSV Fridge Temp Flashing??
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RS21FCSV Fridge Temp Flashing??
Viewing 15 posts - 1 through 15 (of 15 total)
  • #55907
    clubberlang
    I bought this fridge off ebay last week and for the past couple of days the fridge temp light keeps flashing. Ive set it at 2 degrees but its still flashing and the fridge doesnt seem very cool. My milk went off this morning when the temp was set at 4 . The bottom half of the fridge seems ok but the top half seems warmer. I shelled out 440 for this fridge and cant afford for it to break on me as we havent alot of money so any help would be greatly appreciated.
    #325538
    Re: Samsung RS21FCSV Fridge Temp Flashing??
    HI
    You’ll probablly need,evap cover maybe defrost heater also.
    e-mail me samsung@ffrservices.co.uk and i will send over cost.
    Bryan
    #325539
    clubberlang
    What checks can i perform so as i definatly know which part i need as i dont wanna buy a part on what i probably need. I found this thread on here http://www.ukwhitegoods.co.uk/modules.p … ge&pid=209 and am going to check these out today.
    #325540
    clubberlang
    Seems now that my freezer top portion is also defrosting could this be another problem?? I think im gonna ring the fella i bought it from and see what he has to say 🙁
    #325541
    clubberlang
    Update on problems well today the fridge fan has been making lots of noise when its closed and when i open the fridge door the fan kind of judders to a halt. The freezer temp isn’t in the plusses anymore its dropped to -3 and the fridge temp has dropped a couple of degrees to 14. Could this have been caused by me not keeping the fridge upright when transporting it to my house?? I did leave it 24 hours before plugging it in so i cant see why it should’ve. Can anyone help me sort this out i emailed bryan with no reply as of yet.
    #325542
    clubberlang
    Anyone? 🙁 🙁 🙁 🙁
    #325543
    machineman
    switch it off let it defrost overnight or maybe 2nights
    leave fridge door open, it has iced up behind the back panel
    could be a number of things
    evap heater -gutter heater- sensor or just a cut out
    the noise you here is ice hitting the fan
    clubberlang
    I took off the evap cover and it was all iced up behind it so im leaving it to defrost and ill see what happens when i put it back on hopefully it will be fixed should i carry out the checks with the multi-meter on the defrost heaters? My evap cover looks alot like the one pictured in this tutorial here with the same clips ect has this been fixed before or do they come like that. http://www.ukwhitegoods.co.uk/modules.p … ge&pid=209
    Also i have a multi meter but im not that savvy on using them i tried but didnt get any readings like the ones i should’ve. The guy i got it from has agreed to get me a new evap cover will the solve the problem??
    #325545
    clubberlang
    Redid the multi meter tests after finding another guide on ebay and all where fine this is the guide http://reviews.ebay.co.uk/Samsung-RS21- … 0005678075.
    #325546
    If your not compident in using an electrical tester then get an engineer in..we cannot give any advise concerning the use of test equipement.
    Bryan
    #325547
    clubberlang
    Hi Bryan i emailed you but no reply i did the tests with the multi meter and they where fine so i guess just an evap cover as you suggested?
    #325548
    machineman
    no
    #325549
    clubberlang
    machineman wrote:no
    😕 😕 😕 Not an evap cover then? Also i took some photos of what it was like if these will help if ya need to look then i can upload them.
    #325550
    clubberlang
    After taking the evap cover off to defrost it the problem was fixed but is now making the noise from ice hitting the fan again so something still isnt right any ideas?
    #325551
    EestiNick
    Look for the forum thread ‘F-DEF ERROR ON SAMSUNG RS21’
    All information is there. 🙂
