Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Samsung RS21NCMS, problem with fridge…
- This topic has 8 replies, 6 voices, and was last updated 18 years, 10 months ago by
leannedarren1.
June 13, 2007 at 3:04 pm #28103
leannedarren1
ParticipantHi there,
I’m having a problem with my samsung fridge (RS21NCMS). A few nights ago it started to make a really funny noise that to me sounded like the fan. Since then the fridge has stopped working and isn’t cooling 🙁 It’s only 3yrs old but samsung don’t want to know 😡
Does anyone have any ideas as to what could be the problem, any help much appreciated 😀
Many thanks
Leanne. 😀June 13, 2007 at 5:03 pm #216908Dales-Electronic
ModeratorRe: Samsung RS21NCMS, problem with fridge…
First things first do this – press and hold the top two facia buttons, the display will start to flash (keep the buttons held in), the facia will go blank and then tell us if any of the lines that make up the freezer/fridge numbers light up. This will indicate what you need replacing. In all probability you will need an evaporator cover, a temperature sensor and possibly a thermal fuse.
June 13, 2007 at 6:41 pm #216909leannedarren1
ParticipantRe: Samsung RS21NCMS, problem with fridge…
Thanks. I’v just done the self diagnostic check (I assume thats what you would call it) and the display stayed blank for about 20 seconds then just returned to the temperature settings screen as normal. I’m assuming this means that the pcb’s and compresor etc are functioning properly? Now what do i do 😆
Darren
June 13, 2007 at 6:56 pm #216910leannedarren1
Just to add. The fridge is over 3 years old now and this is the first problem we have had. I removed the internal covers off this afternoon and the bottom left area had a build up of ice, of which i have now got rid of by leaving the fridge off for 5 hours. Everything now seems to be working fine but after reading other posts on this board i believe this to be only temporary.
Darren
June 14, 2007 at 7:05 am #216911Dales-Electronic
You will probably need to change the evaporator cover if there is no great issue with ice build up. This can be sourced from ‘shop@’ on the left sidebar.
June 15, 2007 at 8:26 pm #216912admin
KeymasterRe: Samsung RS21NCMS, problem with fridge…
Hi Leanne
If your display is showing blank then the probable cause will be the defrost sensor,this will stop the unit defrosting but doesnt always show as an error code.
If you find that you still have a problem then chage this and it should cure your fault.
Bryan
May 27, 2008 at 9:57 pm #216913shaun1975
Hi guys this is the problem i have i believe, and i just held the top 2 buttons in and on the fridge temp side the second digit the bottom line light up, does this help? also contacted a repairs@ like you mentioned.
September 4, 2014 at 10:09 am #216914scouse_sedley
Hi I have this same fridge freezer I have pressed the top 2 buttons on the screen it flashed and went blank then a line appeared where the fridge temperature would be any ideas what this is please
September 4, 2014 at 4:07 pm #216915SAMURI
If you pressed the top 2 buttons and held them in for a few seconds you have gone into the engineers setting Mode.
If it has not returned to the normal display the turn it off at the mains and leave it off for 15 mins.
When you turn it back on it should reset to the normal display.
Bob
