Samsung RS21NCMS problems
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RS21NCMS problems
  • #57521
    CountZero
    hullo, first post and all.
    read some threads on here a couple of weeks ago when the unit started making a load of noise that stopped when the fridge side was opened, thanks to the advice on here i stripped it apart, defrosted it and reassembled.
    all has been fine for a couple of weeks but now there is visible frost inside the fridge again, so i’m guessing a part needs replacing.
    if i hold the two buttons down on the display, eventually it shows the middle segment of the numeral 8 on the fridge temp side (in line with the degrees symbol) if that helps any of you clever types fault find.
    when i had it in bits, a small part on the evaporator assembly did look like it might have burnt out (wish i’d taken a pic now) but couldnt be sure if it had or if it was that black gumstrip they sometimes use to hold things in place.
    any help greatly appreciated as i dont really want to have to buy a new fridge if this one can be repaired.
    thanks in advance 😉
    #331399
    clubberlang
    Re: Samsung RS21NCMS problems
    http://reviews.ebay.co.uk/Samsung-RS21- … 0005678075
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=209
    Have a look at these maybe they will help you
    #331400
    CountZero
    thanks, that’ll keep me busy reading 😉
    #331401
    grangy123
    the evaporator cover and fan need replacing.i sell them on e/bay regards john
    #331402
    The fan doesnt need replacing as they VERY rarely fail.in fact in the 5 yrs ive been a samsung engineer i havent replaced a fan for being faulty.Also bearing in mind the evaperator cover comes as a complete unit and is normally a consiquence of something else that has failed..ie heater,thermal fuse,sensor,drain heater.
    e-mail me some pictures of how its frozen up without defrosting it and i will let you know what has failed.
    Bryan samsung@ffrservices.co.uk
    #331403
    CountZero
    thanks r600a, the frost has started binding on the fan again so i’ll have to pull it apart once more in a day or so (once the wife cooks the chicken etc. thats in there at the mo) so can take plenty of pics 😉
    #331404
    CountZero
    email sent, now back to thawing the cover and fan with the wife’s hairdryer 🙁
