samsung rs21ncns
  • #55479
    comptonappliances
    wont start up on switch on is there a test procedure/ fault codes for this appliance thanks
    #324082
    funkyboogy
    Re: samsung rs21ncns
    R U getting anything on the display ??…
    most common prob when completley deed .. is icemaker sensor (little wires that run under icemaker. they twist with ice tray and normaly break )taking out the whole unit …
    if this is the case … top – segment on pcb display will be flashing ..
    you can cut-out bad portion of sensor wire and make a temp join to get f/f working .. but will need a new ice maker to complete job..
    ally
    #324083
    BobHope
    emailed a little info for you.
    Bob.
