Samsung RS21WCNS Fridge freezer, Fridge not cold
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung RS21WCNS Fridge freezer, Fridge not cold
  • #54327
    EZappliances
    Hi all, Sold one of these used Samsung fridge freezers to a local customer. He complains that after a few days the fridge becomes warm even though the digital temperature read out indicates the temperature is correct. If the unit is un- plugged then plugged back in, the temperature read out then correctly displays the excessively warm temperature, it then goes on to cool the fridge correctly for a couple of days before the the original problem returning. I have heard that the evaporator fan cover can cause problems by jamming the fan, but if this was the case surely the temp read out would show the excessive temp? Do I possibly have a temp sensor problem? Any ideas welcome as I am not too familiar with this range of fridge freezers. Thanks
    #319225
    Re: Samsung RS21WCNS Fridge freezer, Fridge not cold
    defrost sensor,heater,thermal overload all in the fridge.
    bryan
    #319226
    EZappliances
    thanks for the info , is it possible to get a service manual for this Samsung so I can familiarise myself with the intricate workings of this model as I have no previous experience of these American style fridge freezers
    #319227
    EZappliances
    Ok, have had a more detailed look at this problem and it seems the main defrost heater has gone OC, it should read 480 ohms, but this one is completely OC. Does anybody know if the defrost heater is available as a spare part or does one have to replace the whole evaporator?
    Thanks for any help as I would like to draw this one to a conclusion that leaves me a little profit :o)
    #319228
    Cras
    normally come with the evaporator but u can un clip the heater from them so no need to change evap. 😀
    #319229
    chezza
    fridge defrost heater is now available on it’s own , whereas you used to have to get it as part of evaporator assy 😀
    #319230
    funkyboogy
    would aslo test drain hole heater … common fault
    evap assy with heater da96-000013h
    cant remember drain heater …
    you should get your customer to call samsung and get safety fuse kit done if its not already been done ..
    and if your lucky they might repair fridge fault aswell
    fb
