Samsung RS21WCNS (RS21WCNS1/XEU) Fuse Problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung RS21WCNS (RS21WCNS1/XEU) Fuse Problem
  • #58908
    TeeMyob
    Hello,
    I am having trouble with a customers Samsung RS21WCNS (RS21WCNS1/XEU).
    It is the model with the Water dispenser built into the fridge door (right hand side fridge0
    There is no Ice maker, just manual fill water tank.
    The 2Amp Glass fuse on the main board keep blowing.
    The customers mate had disconnected all the connectors from the board and the fuse blew immediately when powered with 240v Mains.
    When I arrived, not blowing even a 600mA fuse. But soon after running in refrigeration mode, the fuse pops.
    Anyone else had this problem?
    In my experience, Samsung USA Style boards don’t normally fail.
    TM
    #336084
    Re: Samsung RS21WCNS (RS21WCNS1/XEU) Fuse Problem
    Get the customer to contact samsung as they have a 5 yr limited warranty for this fault.
    otherwise its the defrost heater but the complete fuse board must be replaced as a unit.
    Bryan
    #336085
    TeeMyob
    Fridge or freezer defrost heater R600a?
    I know about the board fuse mod. But the fuse blows with nothing connected.
    TM
    #336086
    TeeMyob
    compressor maybe?
    I had cleared my van out and left my megga in the garage.
    Will have to go back, just a bit in the sticks
    TM
    #336087
    TeeMyob
    R600a?
    TM
    #336088
    If it’s tripping then you have a earth leakage fault somewhere.you will need to check the different circuits.
    Bryan
    #336089
    funkyboogy
    LIGHT BULB ….
    also maybe pcb … it self
