samsung RS7 service information required
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries samsung RS7 service information required
  • #91485
    char14lew
    I have one of these to go to, can someone suply a service manual please?
    many thanks Darrell
    #448299
    funkyboogy
    Re: samsung RS7 service information required
    whats the issue you having with it — service manuals not so easy to get but ive worked on lots if them
    also do you have full model — as some are rsh7 dnmh or you have rs75 ???
    ally
    #448300
    char14lew
    thanks for the reply Ally,
    the customer said model is RS7567BNCSP but I think it should be BHCSP?
    S/N: 9744EBF900364Y
    Problem is ice maker not working and water not coming out cold.
    freezer temp is -20 and food frozen as normal, fridge temp ok also.
    I’ve not done one before so was after test info etc for future ref.
    for ice maker would check it’s on on control panel then try reset but how can water be warm if fridge temp is ok? cheers Darrell
