Home › Forums › Trade Technical & Spare Parts Forums › Trade Spare Parts › Samsung RSG5DURS Diverter solenoid
- This topic has 15 replies, 4 voices, and was last updated 13 years, 7 months ago by
stevebunyan.
August 21, 2012 at 9:51 am #71058
stevebunyan
ParticipantMorning, does anyone have the part number for this?
I think it is listed as a motor step valve on connect but nothing comes up when you click on the part!!!!
Steve
Sent from Steves
iPhone using TapatalkAugust 21, 2012 at 5:52 pm #379914stevebunyan
ParticipantRe: Samsung RSG5DURS Diverter solenoid
Masterfix say they can supply but only if I can give them a part number.
Any help appreciated.
Sent from Steves
iPhone using TapatalkAugust 21, 2012 at 7:18 pm #379915BobHope
Hi Steve,
try DA9703125A assy motor step valve.
Bob.
August 22, 2012 at 10:02 pm #379916stevebunyan
Thanks Bob
Sent from Steves
iPhone using TapatalkOctober 12, 2012 at 8:45 am #379917stevebunyan
Morning chaps
Fitted new step valve, caved out and re-gassed. Now not getting cooling to fridge or freezer where as before it was just the fridge that was warm. I’m thinking blockage but would like some input please.
Has any one experienced this and did you come up with a fix?Thanks in advance
Sent from Steves
iPhone using TapatalkOctober 12, 2012 at 8:51 am #379918stevebunyan
Just an update
The Freezer as come right over night but still no cooling in the fridge which was the original fault,
Suggestions very welcome.
Sent from Steves
iPhone using TapatalkOctober 12, 2012 at 6:36 pm #379919stevebunyan
Anyone
Sent from Steves
iPhone using TapatalkOctober 12, 2012 at 7:03 pm #379920BobHope
hi steve,
i dont have access to the samsung site now but im sure that the appliance could be put into forced operation load tests to check the diverter valve, maybe someone with access to he site can forward this to you, good luck.
Bob.
October 12, 2012 at 10:18 pm #379921stevebunyan
Thanks Bob
Does any one have that info?
Sent from Steves
iPhone using TapatalkOctober 13, 2012 at 10:17 am #379922bryan-206
Top left and middle right button for 8 secs. Beep beep and blank display. Middle right will cycle through functions. Cooling and defrost. Forced operation must be used when gassing I believe as only freezer circuit is open on initial power up. Unless forced otherwise
October 13, 2012 at 8:27 pm #379923stevebunyan
Hi Bryan
Thanks for the info, could you explain what you mean by the freezer circuit only open on start up?
And forced start required.
Does that mean that customers have to do a forced start when first turned on?
Sent from Steves
iPhone using TapatalkOctober 13, 2012 at 8:36 pm #379924admin
KeymasterRe: Samsung RSG5DURS Diverter solenoid
Hi Steve
It means the valve only opens on the freezer side till a temperature is reached and you need to force the fridge side to run when fitting a compressor and re-gassing.
Bryan
October 13, 2012 at 8:45 pm #379925stevebunyan
So will the fridge eventually kick in once the freezer has reached temp?
Sent from Steves
iPhone using TapatalkOctober 13, 2012 at 10:34 pm #379926admin
NO
The system will be under charged
bryan
October 15, 2012 at 8:38 pm #379927stevebunyan
Hi Bryan
The system is freshly charged with R600a. What would you suggest? Am calling to have another look tomorrow morning.
Cheers Steve -
