samsung RSH1DBBP fridge dain blocked
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries samsung RSH1DBBP fridge dain blocked
  • #91678
    char14lew
    Anyone come across the fridge drain hole blocked before?
    I’ve tried boiling water,steamer (which normally melts any ice) and long cable tie from both ends but can’t seem to unblock it!
    other than going back with some stiff wire, are there any other suggestions?
    cheers Darrell
    #448954
    Re: samsung RSH1DBBP fridge dain blocked
    if its ice have you tried adding a bit of salt to try and melt it ?
    Simon46
    Thats an idea. Never tried that.
    #448956
    thedoood
    A cheap hand held steamer clears away all…
    #448957
    thedoood
    Oops sorry never saw you had tried the steamer…
    #448958
    char14lew
    thanks Dave, I’ll try the salt although i’ve never had a problem not being able to melt the ice with the steamer in the past!
    cheers
    #448959
    is there not a little gauze filter thing in these pipes? Had a rusty evaporator tray once and all the rusted bits were sitting on this filter in the pipe blocking it. Had to remove pipe from back to clean out.
    #448960
    Get yourself a wallpaper stripper and don’t use the plate just point the hose down the drain. then remove the one way rubber valve and leave it off.
    Bryan
    #448961
    Lawrence
    OR remove the rubber flap on the end of the drain tube and put your steamer nozzle up there and have a cup of tea- eventually it will shift
    #448962
    char14lew
    done that guys thanks. when I went back it had cleared, so must have just been solid with ice. Not had one that bad before!
    Darrell
