I have recently bought a Samsung RSH1DBBP Fridge Freezer (for £250) from the Regional Repair Center
I was led to believe it was in full working order, (just a little dented along the sides)
After having in plumbed in I have noticed that the ice maker doesn’t produce ice automatically
Water fills the ice tray and once frozen as I understand it a sensor underneath the ice tray should make the ice tray rotate and the ice should then fall into the ice collector
Unfortunately the only way I can get ice into the ice collector is by pushing the reset/test button underneath
(This results in the ice tray rotating a little over 90 degrees, the right hand side twists down first, (it doesn’t go down in parallel))
I had an engineer round from the place where I bought the freezer from who replaced this part DA97-07621B EVAP
Despite dropping the temperature of the freezer to -25 still no ice is automatically produced
The Engineer also re-gassed the compressor
Any ideas as to why the Ice Maker doesn’t work? and what parts I need to get it working again?
