Re: SAMSUNG RSH1DBBP WATER FROM DISPENSER NOT CHIILED
The flow of water in the system is as follows – water enters at the rear, is fed into a water tank in the fridge where it is chilled. Once you press the lever at the front, the water is forced out of the chiller tank across the front and up inside the door and then into the glass. To get the chilled water through you usually have to run abit off that is still warm. Its like the hot tap into the sink in the morning but in reverse. If having run a couple of glasses through you still have warm water you need to call an engineer. Second point, some of these have a water bottle rather than mains water feed in the fridge door if this is your appliance then perhaps you need to turn the fridge temp down abit or else leave the water in longer to cool 8)
