Samsung RSH1DBMH (fan?) Noise Problem please!
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Samsung RSH1DBMH (fan?) Noise Problem please!
  • #54511
    PMD
    I have a Samsung RSH1DBMH which is just under 3 years old (Jul 07) and has recently begun making a loud noise similar to an overworked fan coming from the top of the fridge at the back. The noise stops when I open the frridge door and re-starts after several minutes. It has become progressively louder in the last few days.
    I unscrewed the rear assembly at the base of the fridge last week and gave it a proper clean by removing a build up of dust which apopeared to temporarily clear the problem however the noise has now returned and I suspect the absence of noise was due to it having been switched off for a good while whilst I cleaned/defrosted it.
    Anyway, it sounds like a fan or equivalent but wish to know if it’s something I can fix or will require an engineer to visit..? (Nothwithstanding the challenges of Internet diagnosis!)
    #319867
    chezza
    Re: Samsung RSH1DBMH (fan?) Noise Problem please!
    call samsung for a free of charge repair
    #319868
    PMD
    Thanks – but I only have a 24 month warrant so presume that would be chargeable..?
    #319869
    chezza
    not for this 😆
    just dont tell them you have had it in pieces though
    #319870
    PMD
    chezza wrote:not for this 😆
    Ok – thanks – I won’t!
    Any inkling what the problem might be..? As a point of reference for whatever Samsung say it is…
    Help much appreciated! 🙂
    #319871
    chezza
    if you report it as you have here ; noise from the fridge that stops when you open the door…. it is likely to be a build up of ice around the fan causing your problem
