Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Samsung RSH1DBMH Fridge Freezer
- This topic has 10 replies, 3 voices, and was last updated 14 years, 9 months ago by
Hollytree_Technical.
July 5, 2011 at 9:19 pm #63774
Hollytree_Technical
ParticipantHi all
Would anyone be able to supply me with a service manual and any service bulletins for the above machine please?
Thank you
Jem
July 8, 2011 at 12:45 pm #354864Hollytree_Technical
ParticipantRe: Samsung RSH1DBMH Fridge Freezer
Anyone?
Jem
July 8, 2011 at 5:20 pm #354865BobHope
hi jem
pm me your email address.
whats up with your appliance ?.
Bob.
Email Sent
July 8, 2011 at 6:42 pm #354866Hollytree_Technical
Hi Bob
Thank you for the e-mail – will sit and read them a bit later.
It isn’t keeping temperature in the fridge – when I went to look the first time it was iced so solid I couldn’t get the cover off, its in a holiday let and the holiday makers decided to live with it rather than turn it off for a day or two so I could fix it, will be going back tomorrow morning to look at it and try and work out why it is that badly iced.
Any suggestions or pointers will be much appreciated.
Thank you
Jem
July 8, 2011 at 6:55 pm #354867BobHope
some more info sent.
Bob.
July 8, 2011 at 7:06 pm #354868admin
KeymasterRe: Samsung RSH1DBMH Fridge Freezer
Hi Jem
I can supply the parts needed.
Bryan
July 9, 2011 at 12:45 pm #354869Hollytree_Technical
Hi all
Thank you for the extra info Bob – looks like it is one that does need modifying.
Might be contacting you Bryan for parts once people have confirmed/denied what I have said below.
Before I order the mod kit I wonder whether I could pick peoples brains a little more (I don’t see much Samsung stuff for repair) – I don’t appear to be getting any circulation from the refrigerator fan – I put the unit into self test diagnostic mode and got no errors showing, I then put the unit into forced diagnostic mode and measured 10v going to both the compressor fan and the freezer fan but not the refrigerator fan (labelled R-fan on board), I assume that it should be running all 3 fans at this point? I have also taken the fan out and tested the coils with a multimeter and got continuity so then connected it to a 9V battery upon whence it happily spun, I assume that it brings both fridge and freezer back to temperature in one go and doesn’t do them one at a time? Would people agree with my diagnosis that the main board is knackered?
Thank you
Jem
July 9, 2011 at 4:15 pm #354870admin
Nope,I’m pretty sure you’ll only need 2 mod kit’s , 1 fuse board and 1 sensor / evap cover mod kit.if the evap cover is heavily iced up then it would be better to change it also.
Bryan
July 9, 2011 at 4:53 pm #354871Hollytree_Technical
Perhaps I should have mentioned that it had been left turned off for 5 days before I went back so was completely free of ice, I was/am just surprised that it appears to make no attempt at all to spin the refrigeration fan even in the forced operation/forced defrost test mode.
when you say sensor/evaporator mod – I assume that you mean part no “DA81-01997A”, so what is the fuse board mod kit meant to correct/change?
Thank you for your help so far
Jem
July 11, 2011 at 1:40 pm #354872admin
fan will not run with door open? just a hint
July 11, 2011 at 2:29 pm #354873Hollytree_Technical
fan will not run with it open or closed (tricked it with a magnet and waited several minutes as well to make sure)
Jem
