I’ve just started to get a problem with my Samsung RSH1DBMH fridge freezer. The freezer doesn’t seem to be getting down to temperature (set to -18). Although the front panel says it’s at -18 it obiously isn’t – icecream and other items are defintely soft! Switching the appliance on/off seems to reset the temp reading – it then displays -4 and then over a period of an hour or so goes back down to -18. After leaving it for another hour or so, I checked again – items are still soft! Turning off/on again shows a reading of -4 again…..
I googled for to see if this was a common problem – picked up lots of hits for R21 problems. So I followed some instructions remove the various screws/covers to get at the fan. There was some ice present but not alot (i.e. the drainage hole wasn’t blocked). I defrosted what ice there was present, reassembled and turned back on. Doesn’t seem to have fixed the problem.
Any idea what might be wrong, and if so, what the resolution is? Does this fridge share the same design issues that the RS21 has?
Thanks,
Ian
