Hi Guys
Anyone got a guide to what the engineers menus are, There are two menus when you hold a press power freeze and vacations button.
I have install a R Def sensor and modification kit to the fridge. This has cleared my error, but we had to have a friend over to changed the compressor that was dead, when i went to adjust the menu for the r def offset i did not read the instructions correct and change a menu option on the first engineers menu 15sec in i change this to 13 and 3 but it should have been on the second menu options and set as 3 and 13. I have no idea what the first menu should be set back to?
My main issue is that i have a new compressor fully gassed, no error on the menu and the freezer and fridge get to temp but the compressor is not cutting our at temp.
Advise suggestions please.
Adrian
