Hi Guys
My main issue is that i have a new compressor fully gassed, no error on the menu and the freezer and fridge get to temp but the compressor is not cutting our at temp.
I have checked all seals, fans, sensors, used a external thermometer and shows correct temp.
The compressor is not cutting our at temp and feel it may be a menu setting i have changed I.e constant run etc
I have install a R Def sensor and modification kit to the fridge. This has cleared my error, but we had to have a friend over to changed the compressor that was dead.
when i went to adjust the menu for the r def offset i did not read the instructions correct and change a menu option on the first engineers menu 15sec in, i change this to 13 and 3 but it should have been on the second menu options and set as 3 and 13. I have no idea what the first menu should be set back to?
Advise suggestions please.
Adrian
