Samsung RSH1DTMH FF Back Panel Burnt.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung RSH1DTMH FF Back Panel Burnt.
  • #76579
    dave-m
    Has anyone seen this?
    I’ve one of these which has a hole burnt in the back panel behind the evaperator/defrost heater.
    The heater tests fine and the diagnostics shows no faults. The evap was doing the usual act of icing up.
    But when I pulled it apart to look at it i found a small crack above the evap and I followed it down and there is a 3″ hole burnt in the back panel behind the bottom of the evap and through some of the insulation.
    New to me, I can only assume its the heater but it show no damage.
    Re: Samsung RSH1DTMH FF Back Panel Burnt.
    Have you read about the RECALL?
    #398829
    dave-m
    Thanks Martin,
    I didn’t know about that one.
