Samsung RSH1DTMH – fridge temperature won’t set
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Samsung RSH1DTMH – fridge temperature won’t set
  • #73650
    davidelliot
    A client has contacted me about their Samsung RSH1DTMH side by side fridge freezer.
    The freezer section is absolutely fine.
    However; the temperature in the fridge section won’t chill down – it’s always too warm.
    When the temperature is set to 4 deg C using the control panel, the display shows 4 for a few seconds and then reverts back to a higher temperature, like 11 deg C for example.
    They have tried unplugging the fridge freezer for a few minute then plugging it back in – still the same problem.
    Any ideas please?
    Cheers – Dave
    #388288
    funkyboogy
    Re: Samsung RSH1DTMH – fridge temperature won’t set
    will probaly need new back cover , defo sensor and possible defo element ..common fault – would advise to call samsung 1st they may cover it under warranty ..
    #388289
    davidelliot
    When you say “will probaly need new back cover”, are you referring to the cover at the back of the f/f or the back cover inside the refrigerator compartment?
    Sorry if that sounds.. erm.. dumb!
    Cheers, Dave
